Beiträge von Ronnie
    Hoffentlich bald neue Connect firmware ins WWW verfügbar...
    For European owners this version (7000C0A-EU01_11000), is now available at your local Mazda dealer, changes from 10049:
    (Ver. 7000C0A-EU01_11000)
    • The center display may turn black right after starting.
    • It may repeat rebooting right after starting. Removing navigation SD card stops rebooting.
    • When playing music using an USB connected iPhone, album artwork may not appear.
    • Android AutoTM may not appear on the entertainment screen.
    • When a Bluetooth® device is disconnected, the screen may freeze.
    • When it reboots, registered information for a paired Bluetooth® device may be lost.
    • When the gear is shifted from reverse position to parking position, the center display may turn black.
    • When listening to the radio, steering switch operation for auto-tuning may erase the banner.
    • Update Navigation-Software to IGO 9.35.2.252728
    (Ver. 7000C0A-EU01_10051)
    • While playing audio tracks using Android AutoTM and displaying the map using Android AutoTM, turning the main power off may lead to a reboot.
    • Voice command may not be recognized.
    • Warning message may appear leading to a reboot.
    • The 360° view monitor screen may be overlaid with the home screen.
    • While using Android AutoTM, turning the main power off may lead to the display to keep turning on.
    • After particular operations, the parking sensor screen may freeze.
    • While multiple USB devices are connected, track selection using voice command may result in the error message “Too many tracks. This function is not available”.
    (Ver. 7000C0A-EU01_10050)
    • It may reboot when using the map function on CarPlayTM.
    • [For workshop] DTC U3000:49 (CMU internal malfunction) is detected when music play is disturbed even caused by the mobile device application.
    • Voice command for artist name or album name is not accepted with error message “Voice Recognition Unavailable. Voice Recognition commands for music are unavailable. There is no available metadata on this device.”
    • When using voice command “Call Time Signal”, it may freeze at the phone call screen if Bluetooth® connection has been interrupted.
    • If the main power is turned off and then on quickly, while a Bluetooth® device is connected, Bluetooth® connection may not be resumed.
    • After connecting a device to use Apple CarPlayTM, turning the main power on may lead to a reboot.
    • After changing the distance unit in the system setting display, the energy efficiency unit in the EcoEnergyManagement screen may not change.
    • Language selection may fail to change.
    • Android AutoTM may fail to connect.
    Skyhessen
    Mir war klar, dass es bei den beiden TSI um unterschiedliche Dinge geht. Ich denke, der Kern des Posts, auf den ich verlinkt habe, ist, dass die US-Händler verwirrt sind über die Warnung, den MX-30 nicht zu aktualisieren, und das gleiche beim CX-30 missverstehen. Auch wenn es um etwas anderes geht im selber Modul.
    Ich ziehe mich weiter von diesem Thema zurück. Ich habe einen "alten" CX-30, der die Warnung überhaupt nicht ausgibt.
    Auslandsforum Bericht, sehe https://www.cx30talk.com/threa…-terrible.2436/post-23735, übersetzt:
    Es sieht so aus, als hätte Mazda endlich etwas getan, es gibt jetzt ein VCM-Update (Vehicle Control Module) für uns europäische Besitzer, um einige TSR-Probleme zu beheben, wie zum Beispiel:
    1) Wenn das Fahrzeug ein Geschwindigkeitsbegrenzungsschild zum Überqueren einer Straße in einem Wohngebiet passiert hat, wird eine niedrigere Geschwindigkeitsbegrenzung als die tatsächliche in der aktiven Fahranzeige angezeigt.
    2) Sobald eine niedrigere Geschwindigkeitsbegrenzung als die tatsächliche angezeigt wird, dauert sie lange an.
    3) Wenn das Fahrzeug ein Geschwindigkeitsbegrenzungsschild mit einem Zusatzzeichen „!“ überfährt, wird die Geschwindigkeitsbegrenzung nicht in der aktiven Fahranzeige angezeigt.
    Ihr örtlicher Mazda-Händler sollte darüber informiert sein, wenn nicht, bitten Sie ihn, TSB R039/22 oder SI122909 nachzuschlagen.
