Einige Anleitungen zur Demontage "Interior Trim" Bauteile (engl.):
(mit z.T. weiterführenden Links innerhalb der Kapitel)
(1) Plug hole plate (SKYACTIV-G 2.0) (See PLUG HOLE PLATE REMOVAL/INSTALLATION [SKYACTIV-G (WITHOUT CYLINDER DEACTIVATION (E))].) (See PLUG HOLE PLATE REMOVAL/INSTALLATION [SKYACTIV-G (WITH CYLINDER DEACTIVATION (E))].)
(3) Engine cover (SKYACTIV-X 2.0) (See ENGINE COVER REMOVAL/INSTALLATION [SKYACTIV-X 2.0].)
(4) Rear wall (SKYACTIV-X 2.0) (See SIDE WALL REMOVAL/INSTALLATION [SKYACTIV-X 2.0].)
(5) A-pillar trim (See A-PILLAR TRIM REMOVAL/INSTALLATION.)
(6) Front scuff plate (See FRONT SCUFF PLATE REMOVAL/INSTALLATION.)
(7) Front side trim (See FRONT SIDE TRIM REMOVAL/INSTALLATION.)
(8 ) Passenger-side decoration panel (See DECORATION PANEL REMOVAL/INSTALLATION.)
(9) Glove compartment (See GLOVE COMPARTMENT REMOVAL/INSTALLATION.)
(10) Dashboard under cover (See DASHBOARD UNDER COVER REMOVAL/INSTALLATION.)
(11) Passenger-side lower panel (See LOWER PANEL REMOVAL/INSTALLATION [(E)].)
(12) Driver-side decoration panel (See DECORATION PANEL REMOVAL/INSTALLATION.)
(13) Hood release lever (See HOOD RELEASE LEVER AND RELEASE CABLE REMOVAL/INSTALLATION [(E)].)
(14) Shift lever knob (MTX) (See SHIFT LEVER REMOVAL/INSTALLATION [C66M-R].) (See SHIFT LEVER REMOVAL/INSTALLATION [F66M-R].)
(15) Selector lever knob (ATX) (See SELECTOR LEVER COMPONENT REMOVAL/INSTALLATION.)
(16) Shift panel (See SHIFT PANEL REMOVAL/INSTALLATION.)
(17) Front console box (See FRONT CONSOLE BOX REMOVAL/INSTALLATION.)
(18 ) Cup holder (See CUP HOLDER REMOVAL/INSTALLATION.)
(19) Side wall (See SIDE WALL REMOVAL/INSTALLATION.)
(20) Rear console (See REAR CONSOLE REMOVAL/INSTALLATION [(E)].)
(21) Driver-side lower panel (See LOWER PANEL REMOVAL/INSTALLATION [(E)].)
(22) Knee air bag module (See KNEE AIR BAG MODULE REMOVAL/INSTALLATION [STANDARD DEPLOYMENT CONTROL SYSTEM].) (See KNEE AIR BAG MODULE REMOVAL/INSTALLATION [TWO-STEP DEPLOYMENT CONTROL SYSTEM].)
23) Center lower panel (See LOWER PANEL REMOVAL/INSTALLATION [(E)].)
(24) Driver-side air bag module (See DRIVER-SIDE AIR BAG MODULE REMOVAL [STANDARD DEPLOYMENT CONTROL SYSTEM].) (See DRIVER-SIDE AIR BAG MODULE INSTALLATION [STANDARD DEPLOYMENT CONTROL SYSTEM].) (See DRIVER-SIDE AIR BAG MODULE REMOVAL [TWO-STEP DEPLOYMENT CONTROL SYSTEM].) (See DRIVER-SIDE AIR BAG MODULE INSTALLATION [TWO-STEP DEPLOYMENT CONTROL SYSTEM].)
(25) Steering wheel (See STEERING WHEEL AND COLUMN REMOVAL/INSTALLATION [(E)].)
(26) Upper column cover (See COLUMN COVER REMOVAL/INSTALLATION.)
(27) Lower column cover (See COLUMN COVER REMOVAL/INSTALLATION.)
(28 ) Clock spring (See CLOCK SPRING REMOVAL/INSTALLATION [STANDARD DEPLOYMENT CONTROL SYSTEM].) (See CLOCK SPRING REMOVAL/INSTALLATION [TWO-STEP DEPLOYMENT CONTROL SYSTEM].)
(29) Light switch (See LIGHT SWITCH REMOVAL/INSTALLATION [(E)].)
(30) Wiper and washer switch (See WIPER AND WASHER SWITCH REMOVAL/INSTALLATION [(E)].)
(31) Joint cover (See STEERING WHEEL AND COLUMN REMOVAL/INSTALLATION [(E)].)
(32) Steering shaft (See STEERING WHEEL AND COLUMN REMOVAL/INSTALLATION [(E)].)
(33) Instrument cluster (See INSTRUMENT CLUSTER REMOVAL/INSTALLATION.)
(34) Center speaker grill (See SPEAKER GRILLE REMOVAL/INSTALLATION.)
(35) Center display component (See CENTER DISPLAY REMOVAL/INSTALLATION.)
(36) Connectivity master unit (CMU) (See CONNECTIVITY MASTER UNIT (CMU) REMOVAL/INSTALLATION.)
(37) Audio panel (with audio panel) (See AUDIO PANEL REMOVAL/INSTALLATION [(E)].)
(38 ) CD player (with CD player) (See CD PLAYER REMOVAL/INSTALLATION.)
(40) Rear heat duct No.1 (See REAR HEAT DUCT REMOVAL/INSTALLATION [(E)].)
(41) Windshield wiper arm and blade (See WINDSHIELD WIPER ARM AND BLADE REMOVAL/INSTALLATION.)
(42) Cowl grille (See COWL GRILLE REMOVAL/INSTALLATION.)
